Re: The Leovinci Moby pipe = NASTY
Ben /
Yeah....Elliot is 100% correct (as usual when it comes to Mobys!)
So, the deal is this:
NO - pedals hit...but with a modifies right crank arm, about 1.5" out, it would work. Kickstand works PERFECTLY...which is great.
And....yes - this is a 40T...so the engine doesn't variate! In other words, everything is ROCK SOLID....all moving points are in a good spot with ZERO chance of moving. There is literally no stress on the exhaust port. And, honestly? My clutch is tuned well so it doesn't grab until higher revs (thank you Chris!) so I get nice take off.
Yes - Maitland is correct - the Doppler is going to run a little better - it's expansion chamber is larger and the header is bigger all the way around until the chamber. But you know? Having ridden both pipes.....and since this is on an UNVARIATED AV7....I have been very impressed. I'm actually wondering if I should have bought that Airsal kit instead for the Moby. Oh well.
Running a 16:16 SHA with a 19mm intake. Ported. 76 jet (probably can go to a 78 or 80!). It has 40 easy.....maybe 45 tops if I really tune things.
Pretty good!
Oh...and yes - the only difference between the 'square' and 'round' arm is the rear swing arm mounting bracketing. As far as I can tell, this pipe is MADE for the 40T. It fit so fucking well, I couldn't believe it. Maybe on 50L's it'll be good too.
Good luck everyone! Nice to know there are more options out there for the Moby!
I think there's a chance to order these right from Leo Vinci - but I dunno.
  The Leovinci Moby pipe = NASTYTopic by: Ben Ben 01/05/08 04:08PM
  Re: The Leovinci Moby pipe = NASTYRe: Dan O Dan O 01/05/08 04:11PM
  Re: The Leovinci Moby pipe = NASTYRe: ✝️TD-THE MORAL AUTHORITY✝️ ✨ ✝️TD-THE MORAL AUTHORITY✝️ ✨ 01/05/08 04:18PM
  Re: The Leovinci Moby pipe = NASTYRe: Shalerrr rrr Shalerrr rrr 01/05/08 04:24PM
  Re: The Leovinci Moby pipe = NASTYRe: Shalerrr rrr Shalerrr rrr 01/05/08 04:27PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/05/08 05:27PM
  Re: The Leovinci Moby pipe = NASTYRe: Responsible Jon Responsible Jon 01/05/08 05:30PM
  Re: The Leovinci Moby pipe = NASTYRe: Bert Bert 01/05/08 06:00PM
  Re: The Leovinci Moby pipe = NASTYRe: steve steve 01/05/08 06:18PM
  Re: The Leovinci Moby pipe = NASTYRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/05/08 06:30PM
  Re: The Leovinci Moby pipe = NASTYRe: Tommy Too Tall Tommy Too Tall 01/05/08 06:50PM
  Re: The Leovinci Moby pipe = NASTYRe: The Gordon's Fisherman The Gordon's Fisherman 01/05/08 08:13PM
  Re: The Leovinci Moby pipe = NASTYRe: elliot elliot 01/05/08 09:43PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/05/08 10:14PM
  Re: The Leovinci Moby pipe = NASTYRe: Bert Bert 01/05/08 10:34PM
  Re: The Leovinci Moby pipe = NASTYRe: Colinswoop . Colinswoop . 01/05/08 10:47PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/05/08 11:58PM
  Re: The Leovinci Moby pipe = NASTYRe: steve steve 01/06/08 12:30AM
  Re: The Leovinci Moby pipe = NASTYRe: Tommy Too Tall Tommy Too Tall 01/06/08 01:42AM
  Re: The Leovinci Moby pipe = NASTYRe: Austin Austin 01/06/08 01:58AM
  Re: The Leovinci Moby pipe = NASTYRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/06/08 03:28AM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/06/08 11:57AM
  Re: The Leovinci Moby pipe = NASTYRe: elliot elliot 01/06/08 04:08PM
  Re: The Leovinci Moby pipe = NASTYRe: peter peter 01/06/08 05:40PM
  Re: The Leovinci Moby pipe = NASTYRe: Bert Bert 01/08/08 12:52PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/08/08 08:00PM
  Re: The Leovinci Moby pipe = NASTYRe: peter peter 01/08/08 08:26PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/08/08 08:28PM
  Re: The Leovinci Moby pipe = NASTYRe: peter peter 01/08/08 08:36PM
  Re: The Leovinci Moby pipe = NASTYRe: The Gordon's Fisherman The Gordon's Fisherman 01/08/08 09:05PM
  Re: The Leovinci Moby pipe = NASTYRe: Bort Hoff Bort Hoff 01/08/08 09:11PM
  Re: The Leovinci Moby pipe = NASTYRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/08/08 10:30PM
  Re: The Leovinci Moby pipe = NASTYRe: elliot elliot 01/08/08 11:44PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/09/08 01:51AM
  The Leovinci Moby pipe = NASTYRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 01/09/08 11:04AM
  Re: The Leovinci Moby pipe = NASTYRe: Graham Motzing Graham Motzing 01/09/08 01:44PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/09/08 02:13PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/09/08 02:35PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/09/08 04:02PM
  Re: The Leovinci Moby pipe = NASTYRe: topher! topher! 01/09/08 08:42PM
  Re: The Leovinci Moby pipe = NASTYRe: elliot of the resistance elliot of the resistance 02/04/08 10:48PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 02/05/08 04:54AM
  Re: The Leovinci Moby pipe = NASTYRe: Bert Bert 02/05/08 10:50AM
  Re: The Leovinci Moby pipe = NASTYRe: Tommy Too Tall Tommy Too Tall 02/05/08 02:19PM
  Re: The Leovinci Moby pipe = NASTYRe: elliot elliot 02/05/08 03:22PM
  Re: The Leovinci Moby pipe = NASTYRe: Tommy Too Tall Tommy Too Tall 02/05/08 03:32PM
