Re: The Leovinci Moby pipe = NASTY
elliot /
one of the creatures bought that pipe at the same time i bought my 1st ninga g3 last year (creature zeke), we compaired the 2 head to head on stock cylinders and malossi cylinders, the ninga had a better top speed in the end.
You can't keep the pedals they hit hard.
Watch out tho, since it was not designed for USA mobys or av7 motors (witch sit at a differnt angle than av10's) the angle of the rotating joint relative the rear mounting location is not optimal and can cuase it to force the joint in a direction it does not want to move when the motor variates, and eventually causes the cylinder exhuast port to become stripped.
this is true for all the expensive AV10 pipes however all the other designs use a more adaptable ball joint that just bairly has enough range so the stress doesn't travel into the exhuast threads, while the leo pipe does not.
At least that was the case on the 50v frame he tried it on, and it indeed did strip out his stock cylinder and then his malossi kit, i can't say it was all the pipe tho, since i did not install it personally. now it sits in the corner of brets garage.
Also since ur using the pipe on a 40 frame it might function more correctly, just make sure the pipe's moving parts are all functioning within thier limits and not stressing the exhuast port threads by having a friend hold the bike and manually variating the motor with your foot or hand on the magneto, watch for any of the moving joints to hit thier limit of movement and transfer the stress into the cylinder and flex blocks. if this is happening you can try and fix the problem by fine tuning the rear moutning location and the angle the pipe is swung around the outside of the bike.
Hopefully on the 40 frame u don't have this problem.
goodluck glad to see some varaitey
  The Leovinci Moby pipe = NASTYTopic by: Ben Ben 01/05/08 04:08PM
  Re: The Leovinci Moby pipe = NASTYRe: Dan O Dan O 01/05/08 04:11PM
  Re: The Leovinci Moby pipe = NASTYRe: ✝️TD-THE MORAL AUTHORITY✝️ ✨ ✝️TD-THE MORAL AUTHORITY✝️ ✨ 01/05/08 04:18PM
  Re: The Leovinci Moby pipe = NASTYRe: Shalerrr rrr Shalerrr rrr 01/05/08 04:24PM
  Re: The Leovinci Moby pipe = NASTYRe: Shalerrr rrr Shalerrr rrr 01/05/08 04:27PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/05/08 05:27PM
  Re: The Leovinci Moby pipe = NASTYRe: Responsible Jon Responsible Jon 01/05/08 05:30PM
  Re: The Leovinci Moby pipe = NASTYRe: Bert Bert 01/05/08 06:00PM
  Re: The Leovinci Moby pipe = NASTYRe: steve steve 01/05/08 06:18PM
  Re: The Leovinci Moby pipe = NASTYRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/05/08 06:30PM
  Re: The Leovinci Moby pipe = NASTYRe: Tommy Too Tall Tommy Too Tall 01/05/08 06:50PM
  Re: The Leovinci Moby pipe = NASTYRe: The Gordon's Fisherman The Gordon's Fisherman 01/05/08 08:13PM
  Re: The Leovinci Moby pipe = NASTYRe: elliot elliot 01/05/08 09:43PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/05/08 10:14PM
  Re: The Leovinci Moby pipe = NASTYRe: Bert Bert 01/05/08 10:34PM
  Re: The Leovinci Moby pipe = NASTYRe: Colinswoop . Colinswoop . 01/05/08 10:47PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/05/08 11:58PM
  Re: The Leovinci Moby pipe = NASTYRe: steve steve 01/06/08 12:30AM
  Re: The Leovinci Moby pipe = NASTYRe: Tommy Too Tall Tommy Too Tall 01/06/08 01:42AM
  Re: The Leovinci Moby pipe = NASTYRe: Austin Austin 01/06/08 01:58AM
  Re: The Leovinci Moby pipe = NASTYRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/06/08 03:28AM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/06/08 11:57AM
  Re: The Leovinci Moby pipe = NASTYRe: elliot elliot 01/06/08 04:08PM
  Re: The Leovinci Moby pipe = NASTYRe: peter peter 01/06/08 05:40PM
  Re: The Leovinci Moby pipe = NASTYRe: Bert Bert 01/08/08 12:52PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/08/08 08:00PM
  Re: The Leovinci Moby pipe = NASTYRe: peter peter 01/08/08 08:26PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/08/08 08:28PM
  Re: The Leovinci Moby pipe = NASTYRe: peter peter 01/08/08 08:36PM
  Re: The Leovinci Moby pipe = NASTYRe: The Gordon's Fisherman The Gordon's Fisherman 01/08/08 09:05PM
  Re: The Leovinci Moby pipe = NASTYRe: Bort Hoff Bort Hoff 01/08/08 09:11PM
  Re: The Leovinci Moby pipe = NASTYRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/08/08 10:30PM
  Re: The Leovinci Moby pipe = NASTYRe: elliot elliot 01/08/08 11:44PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/09/08 01:51AM
  The Leovinci Moby pipe = NASTYRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 01/09/08 11:04AM
  Re: The Leovinci Moby pipe = NASTYRe: Graham Motzing Graham Motzing 01/09/08 01:44PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/09/08 02:13PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 01/09/08 02:35PM
  Re: The Leovinci Moby pipe = NASTYRe: Mike Alanko Mike Alanko 01/09/08 04:02PM
  Re: The Leovinci Moby pipe = NASTYRe: topher! topher! 01/09/08 08:42PM
  Re: The Leovinci Moby pipe = NASTYRe: elliot of the resistance elliot of the resistance 02/04/08 10:48PM
  Re: The Leovinci Moby pipe = NASTYRe: Ben Ben 02/05/08 04:54AM
  Re: The Leovinci Moby pipe = NASTYRe: Bert Bert 02/05/08 10:50AM
  Re: The Leovinci Moby pipe = NASTYRe: Tommy Too Tall Tommy Too Tall 02/05/08 02:19PM
  Re: The Leovinci Moby pipe = NASTYRe: elliot elliot 02/05/08 03:22PM
  Re: The Leovinci Moby pipe = NASTYRe: Tommy Too Tall Tommy Too Tall 02/05/08 03:32PM
