Re: If you were gonna make custom bearings for a Z
philo /
This is going to be a long post...The way to make a two speed live with a kit is you have to make sure your trans is right from the beginning...the two weak points in the two speed is the one way clutch (sprag) if those rollers are at all scored or galled they should not be used or if the roller nut is scored or galled get a good one. This happens because at some point the trans was run low on oil...side case bearings suffer from this too...the other weak point is the urethane pucks in the drive gear when those get sloppy they let the trans hammer itself to death...when you take off from a stand still the sprag rollers are loaded and if you run a lot of power that sprag is really under a heavy load...so it is good to give the bike a hard push out of the hole to help that sprag live next is to take that drive gear apart and get some new urathane pucks ...ive used hard plastic ,shoe goo every thing...rigid uses epoxy and heater hose tried that worked ok ...for a little while problem is when it starts to go the trans starts to chatter and should stop riding the bike or you will hurt it. Another thing is when the bike is about ready to shift, blip the throttle and let it shift don't let it power shift that pounds those rubber pucks. ATF turns thin as water when it gets hot rollers and sprags can,t live in that...0-15 or 5-20 full synthetic is what we use.The pinto that I ran in Kzoo shifted at 40+plus cruises 60+plus that motor is still goin strong in my friends maxi...hope this helps Merry Christmas...philo
  If you were gonna make custom bearings for a ZA50.Topic by: cS cS 12/18/07 12:28AM
  Re: If you were gonna make custom bearings for a ZRe: Chris Paz Chris Paz 12/18/07 02:21AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/18/07 03:29AM
  Re: If you were gonna make custom bearings for a ZRe: vic vic 12/18/07 05:43AM
  Re: If you were gonna make custom bearings for a ZRe: Bert Bert 12/18/07 08:03AM
  Re: If you were gonna make custom bearings for a ZRe: ken ken 12/18/07 11:24AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/18/07 12:11PM
  Re: If you were gonna make custom bearings for a ZRe: vic vic 12/18/07 06:11PM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/18/07 12:26PM
  Re: If you were gonna make custom bearings for a ZRe: Chris Paz Chris Paz 12/18/07 12:44PM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/18/07 09:35PM
  Re: If you were gonna make custom bearings for a ZRe: Matt Smith Matt Smith 12/18/07 10:01PM
  Re: If you were gonna make custom bearings for a ZRe: Graham Motzing Graham Motzing 12/19/07 12:14AM
  Re: If you were gonna make custom bearings for a ZRe: philo philo 12/19/07 02:20AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/19/07 03:38AM
  Re: If you were gonna make custom bearings for a ZRe: osprey osprey 12/19/07 05:37PM
  Re: If you were gonna make custom bearings for a ZRe: philo philo 12/19/07 02:28PM
  Re: If you were gonna make custom bearings for a ZRe: Graham Motzing Graham Motzing 12/19/07 08:14PM
  Re: If you were gonna make custom bearings for a ZRe: philo philo 12/19/07 09:26PM
  Re: If you were gonna make custom bearings for a ZRe: Brock Croy Brock Croy 12/21/07 05:32AM
  Re: If you were gonna make custom bearings for a ZRe: Graham Motzing Graham Motzing 12/19/07 11:41PM
  Re: If you were gonna make custom bearings for a ZRe: Rob K Rob K 12/20/07 12:19AM
  Re: If you were gonna make custom bearings for a ZRe: Rob K Rob K 12/20/07 12:21AM
  Re: If you were gonna make custom bearings for a ZRe: Freebird Freebird 12/20/07 12:36AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/20/07 12:42AM
  the real answerRe: M A M A 12/20/07 01:39PM
  Re: the real answerRe: Matt Smith Matt Smith 12/20/07 01:46PM
  Re: the real answerRe: Silverfox Sullivan Silverfox Sullivan 12/20/07 01:48PM
  Re: the real answerRe: cS cS 12/20/07 06:54PM
  Re: the real answerRe: M A M A 12/20/07 08:51PM
  Re: the real answerRe: M A M A 12/21/07 12:09AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/21/07 01:06PM
  Re: If you were gonna make custom bearings for a ZRe: Graham Motzing Graham Motzing 12/21/07 02:31PM
  Re: If you were gonna make custom bearings for a ZRe: ; . ; . 02/08/08 03:50AM
  Re: If you were gonna make custom bearings for a ZRe: Carl M Carl M 02/08/08 12:44PM
  Re: If you were gonna make custom bearings for a ZRe: homoped homoped 02/08/08 01:56PM
  Re: If you were gonna make custom bearings for a ZRe: ; . ; . 02/08/08 03:15PM
