Re: If you were gonna make custom bearings for a Z
Matt Smith /
you will not be making bearings with better quality/life than stock ones. bearing surfaces aren't so much machined as they are ground (to a very tight tolerance). also the heat treat is quite imporatant.
if you want something better, try to find bearings with a better ABEC rating (or equiv) that fit. or adapt the case to accept something with a better rating.
ex-boeing engineer
  If you were gonna make custom bearings for a ZA50.Topic by: cS cS 12/18/07 12:28AM
  Re: If you were gonna make custom bearings for a ZRe: Chris Paz Chris Paz 12/18/07 02:21AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/18/07 03:29AM
  Re: If you were gonna make custom bearings for a ZRe: vic vic 12/18/07 05:43AM
  Re: If you were gonna make custom bearings for a ZRe: Bert Bert 12/18/07 08:03AM
  Re: If you were gonna make custom bearings for a ZRe: ken ken 12/18/07 11:24AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/18/07 12:11PM
  Re: If you were gonna make custom bearings for a ZRe: vic vic 12/18/07 06:11PM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/18/07 12:26PM
  Re: If you were gonna make custom bearings for a ZRe: Chris Paz Chris Paz 12/18/07 12:44PM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/18/07 09:35PM
  Re: If you were gonna make custom bearings for a ZRe: Matt Smith Matt Smith 12/18/07 10:01PM
  Re: If you were gonna make custom bearings for a ZRe: Graham Motzing Graham Motzing 12/19/07 12:14AM
  Re: If you were gonna make custom bearings for a ZRe: philo philo 12/19/07 02:20AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/19/07 03:38AM
  Re: If you were gonna make custom bearings for a ZRe: osprey osprey 12/19/07 05:37PM
  Re: If you were gonna make custom bearings for a ZRe: philo philo 12/19/07 02:28PM
  Re: If you were gonna make custom bearings for a ZRe: Graham Motzing Graham Motzing 12/19/07 08:14PM
  Re: If you were gonna make custom bearings for a ZRe: philo philo 12/19/07 09:26PM
  Re: If you were gonna make custom bearings for a ZRe: Brock Croy Brock Croy 12/21/07 05:32AM
  Re: If you were gonna make custom bearings for a ZRe: Graham Motzing Graham Motzing 12/19/07 11:41PM
  Re: If you were gonna make custom bearings for a ZRe: Rob K Rob K 12/20/07 12:19AM
  Re: If you were gonna make custom bearings for a ZRe: Rob K Rob K 12/20/07 12:21AM
  Re: If you were gonna make custom bearings for a ZRe: Freebird Freebird 12/20/07 12:36AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/20/07 12:42AM
  the real answerRe: M A M A 12/20/07 01:39PM
  Re: the real answerRe: Matt Smith Matt Smith 12/20/07 01:46PM
  Re: the real answerRe: Silverfox Sullivan Silverfox Sullivan 12/20/07 01:48PM
  Re: the real answerRe: cS cS 12/20/07 06:54PM
  Re: the real answerRe: M A M A 12/20/07 08:51PM
  Re: the real answerRe: M A M A 12/21/07 12:09AM
  Re: If you were gonna make custom bearings for a ZRe: cS cS 12/21/07 01:06PM
  Re: If you were gonna make custom bearings for a ZRe: Graham Motzing Graham Motzing 12/21/07 02:31PM
  Re: If you were gonna make custom bearings for a ZRe: ; . ; . 02/08/08 03:50AM
  Re: If you were gonna make custom bearings for a ZRe: Carl M Carl M 02/08/08 12:44PM
  Re: If you were gonna make custom bearings for a ZRe: homoped homoped 02/08/08 01:56PM
  Re: If you were gonna make custom bearings for a ZRe: ; . ; . 02/08/08 03:15PM
