i kinda ported
i took my kreidler and ported the transfer ports a bit and the intake and exhaust, but not the actually holes in the cylinder.
i noticed its harder to start, and it now goes about 4 mph faster. How the heck do you get to the ports on the inside?
Re: i kinda ported
carefully
Re: i kinda ported
What I've heard is that you don't. The ends of the port on the cylinder side get left alone, too much risk of them catching a ring if they get messed up. If the cylinder bore is chromed it also could flake if you try to enlarge the port.
But I could be wrong.
Re: i kinda ported
success then, congrats!
you should plug chop if you haven't, and re-jet if necessary.
Re: i kinda ported
yeah you've increased air flow and now your engine breathes better, you'll probably need to upjet slightly to get best results
Re: i kinda ported
we all port the "holes" inside the cylinder all the time. thats how you do a port job. there are quite literally hundreds of threads on this many pages long. its totally possible, just takes some forknowledge and the right tools.
do a search on porting and port job. should be enlightening. also yeah, anytime you add performance to a 2 stroke its gonna need more fuel. do a plug chop to be safe or upjet and see if you 4stroke.
Re: i kinda ported
oh did i mention it has a 10 bing?
it has a 72 jet in it right now and its pretty much spot on.
Re: i kinda ported
The Gordon's Fisherman /
I would say that carb is really holding you back. If you were to step it up a bit you might see more of a difference.
