finally a few more av10's in the states, so far the only active bikes i know of are peters, maitlands, brets, eric elk..., shay, and my little yellow 40.
thats 6 so we don't get much support from the moped shops hehe and noone else on these forums will know much about them so there isn't info out there in english really.
a few tips:
You can start a bike that has the idle variator function without a kick starter if u jam the variator slightly closed so the belt rides above the idle bearing in the center then as the bike takes off the thing (cardboard) flys away, bret does this with an er2 and it works great, he also always carries around a little cardboard square thats always getting slightly smaller hehe.
the other thing u need to know about the converstion from av7 to av10 is that the lower mounting spring hardware on the av10 is a mirror image of the av7, so if u buy case halves (don't come with this piece) u can't use the av7 spring mount it will be in the wrong place. so u will have to fab one up or just get a performance tension spring such as the doppler tension spring setup.
check it out its red and cool looking but 60 bones.
another thing to note is that if u use your stock av7 variator the back non moving plate will hit the av10 cases it will either need to be replaced with an av10 back plate or milled down a few mm.
also the head on the bidolot kit can be swapped with a stock av7 head or a stock av10 head both have decomp valves. peter's shredped runs with a stock av7 head as does my little yellow moby since the moter blasted the sparkplug out of my stock av10 one one day.
I also ran the dopper 50cc kit for a bit with its sans decomp high comp head it comes with and it would start up without the decomp as long as the belt was in good shape, the compression wassn't to high on it i guess. the bidalot could be the same.
also u could theoredically buy a sans idle function performance variator, and slap it on and just have the bike stop running when you stop, and run like that till u get the clutch pully. i was going to do this but luckaly for me treats had a clutch pully for a peugeot in sf and i slapped that on.
goodluck with your builds guys hope this info helps
