the 70cc airsal say to use a 7* plug what is this?
probably a number 7 plug, as in NGK bhs7, the heat rating.
Don't forget the capacitating resistor.
Do you mean the flux capacitor??
how much capacitance in the capacitating resistor? 1 farad or 2 but then it would measured not in farad but in OHMs on the the resistor end ,will this stabalize the voltage but increase current?
just go with 60/40 rosin core this way the flux is premixed with the solder
