Re: the importance of timing?
Jerry Franek /
I've been trying something similar--except when setting the rubbing block on the highest point on the loose cam, I try to have the elongated slot of the points set about centered on the tightening down screw. My thought was then I had max adj. available in either direction. I don't understand the Moby experts who say they can set the timing in 3 minutes. And this means that nobody can set timing without a cam puller if it's ever been moved. And lots of folks don't pull the cam. (a couple of mine have heavy plier marks on them, either the PO used water pump pliers to rotate the crank or was trying to pull off the cam). Maybe I'm missing something. If it wasn't freezing out I'd try 1.5 for awhile.
  the importance of timing?Topic by: yumster yumster 12/13/07 01:32PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 01:35PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 01:36PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 01:38PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 01:40PM
  Re: the importance of timing?Re: yumster yumster 12/13/07 03:03PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 03:06PM
  Re: the importance of timing?Re: brystheguy brystheguy 12/13/07 03:24PM
  Re: the importance of timing?Re: yumster yumster 12/13/07 04:12PM
  Re: the importance of timing?Re: brystheguy brystheguy 12/13/07 04:24PM
  Re: the importance of timing?Re: yumster yumster 12/13/07 07:12PM
  Re: the importance of timing?Re: brystheguy brystheguy 12/14/07 02:15AM
  Re: the importance of timing?Re: Jerry Franek Jerry Franek 12/14/07 05:44PM
  Re: the importance of timing?Re: warisesi warisesi 12/13/07 08:36PM
  Re: the importance of timing?Re: Ben Ben 12/14/07 01:29AM
  Re: the importance of timing?Re: Saabsonettguy . Saabsonettguy . 12/14/07 07:41PM
  Re: the importance of timing?Re: Jerry Franek Jerry Franek 12/15/07 10:43AM
  Re: the importance of timing?Re: brystheguy brystheguy 12/15/07 10:50AM
  Re: the importance of timing?Re: Jerry Franek Jerry Franek 12/15/07 01:45PM
  Re: the importance of timing?Re: Jesse Stephenson Jesse Stephenson 12/15/07 08:13PM
  Re: the importance of timing?Re: warisesi warisesi 12/14/07 08:23PM
  Re: the importance of timing?Re: Bert Bert 12/15/07 10:38PM
  Re: the importance of timing?Re: Bert Bert 12/15/07 10:44PM
