Re: the importance of timing?
brystheguy /
OK, here's the deal. Maybe this will make it easier.
When your piston is moving up in the cylinder it squishes the gas/air mixture in to a smaller space or volume. You want spark when it's all squished as you get more power out of the explosion. Most Puchs are set so that the spark fires at around 1.5 mm before the piston reaches the very top of its travel or Top Dead Center (TDC). It sparks just as the piston is reaching the top and everything is super squished. When it sparks, all hell breaks loose and pushes the piston back down to get more gas/air mixture and do it again. If you're timing is set too late, then the spark might be firing when the piston is already on the way down. Not cool. If it's sparking too early, then it kinda slows the piston down as it is on its upstroke. Does that help at all?
  the importance of timing?Topic by: yumster yumster 12/13/07 01:32PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 01:35PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 01:36PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 01:38PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 01:40PM
  Re: the importance of timing?Re: yumster yumster 12/13/07 03:03PM
  Re: the importance of timing?Re: Cory Cory 12/13/07 03:06PM
  Re: the importance of timing?Re: brystheguy brystheguy 12/13/07 03:24PM
  Re: the importance of timing?Re: yumster yumster 12/13/07 04:12PM
  Re: the importance of timing?Re: brystheguy brystheguy 12/13/07 04:24PM
  Re: the importance of timing?Re: yumster yumster 12/13/07 07:12PM
  Re: the importance of timing?Re: brystheguy brystheguy 12/14/07 02:15AM
  Re: the importance of timing?Re: Jerry Franek Jerry Franek 12/14/07 05:44PM
  Re: the importance of timing?Re: warisesi warisesi 12/13/07 08:36PM
  Re: the importance of timing?Re: Ben Ben 12/14/07 01:29AM
  Re: the importance of timing?Re: Saabsonettguy . Saabsonettguy . 12/14/07 07:41PM
  Re: the importance of timing?Re: Jerry Franek Jerry Franek 12/15/07 10:43AM
  Re: the importance of timing?Re: brystheguy brystheguy 12/15/07 10:50AM
  Re: the importance of timing?Re: Jerry Franek Jerry Franek 12/15/07 01:45PM
  Re: the importance of timing?Re: Jesse Stephenson Jesse Stephenson 12/15/07 08:13PM
  Re: the importance of timing?Re: warisesi warisesi 12/14/07 08:23PM
  Re: the importance of timing?Re: Bert Bert 12/15/07 10:38PM
  Re: the importance of timing?Re: Bert Bert 12/15/07 10:44PM
