Ignition timing in a combustion engine is the process of setting the time that a spark will occur in the combustion chamber (during the power stroke) relative to piston position and crankshaft angular velocity. Setting the correct ignition timing is crucial in the performance of an engine. The ignition timing affects many variables including engine longevity, fuel economy, and engine power.
