Review: Moby Mallossi Varioplus variator (AV7)
elliot of the resistance /
YES, a performance variator that dosen't require an extreme setup to function properly!
The Mallossi Varioplus is the answer for those who want to upgrade from the stock unit, but don't want to go the rought of a full performance transmission setup.
I purchased mine from Treats HQ for $66 or so dollers. Basically the Varioplus is a replacement performance moving variator plate. Its made from aluminum with a steel sleeve pressed into the center sliding section. Instead of 3 balls the Vario plus uses 6 rollers. 3 different weight sets come with the unit. There are nine different weight configurations (if the math is right) since you don't have to use all the weights, as long as the plate stays balanced, however mixing the different weights could open up even more levels of tuning i suppose.
So the con of this thing is that it requires complete variator removal and disassembly to install, ok not so bad one time right, well it also requires complete variator removal and disassembly to switch the weights, or better put, to tune.
Luckily for anyone reading this who wants to purchase this unit I have done some leg work for you and give a few weight recomendations at the end.
Installation; here is a wiki page about cracking the variator, use the manuel to remove it from the bike.
http://www.mopedarmy.com/wiki/Motobecane_variator_disassembly
Once the variator is opened you can install the varioplus, it fits right were the stock variating plate normally goes. it also comes with some plastic sleeves that need to be installed over the variator pins coming off the starter clutch assembly so the clutch drum will have to removed to do so.
reinstalling the clutch drum can be tricky since the plastic sleeves make the pins wider and if they are bent a little can make reassembly a bitch, make sure you tighten it down all evenly (4 screws hold it on). The Varioplus comes with a set of allen key replacement screws for this, but I opted to use the original motobecane ones that are slightly shorter and fit better.
Other than the screws, assembly went smoothly, remember to grease up the weights!
I also shaved down the center of the varioplus plate so that it can move further giving me a higher final gear.
As for the weights I used all 6 of the second heaviest set (unlabeled) and it seems to be great, it was the perfect weight, for my setup, i got hella lucky i guess.
If I were running a stock setup completely i'd run all of the heaviest weights and hope its enough. The really cool thing is that this could be used with an AV10 monster motor with the huge amount in weight range on the lighter side, but tuning could be a nightmare!!
My setup for reference is:
Av7 portmatched to a mallossi 62cc kit
Ninja G3 pipe
16:16 dellorto carb with 80 jet
stock large bendy intake
uni filter
old 4l320 belt
mag scrapper rims
stock 50v gearing
stock spring
and the mallossi varioplus (all 6 of the 2nd heaviest weights)
The unit looks stock witch is great since i hate the performance variator blue anodized look.
As for performance, the bike rips out of the hole much better, and keeps that torque all the way thru a now completely seemless power band, the revs are higher at lower speeds so it really takes off well. A scooter rider on a new 150cc bike said he was amazed it could "zip along" so well at a stop light, seriously he was not much faster off the line, i'll take the compliment.
The top speed is slightly better due to the shaving of the variator, and hill power is great it will climb even the steepest hills in San Francisco and right with traffic or faster.
Overall its a great buy and works well with the 62 mallossi kit and a pipe carb AV7 setup, it will surely out accelerate and maybe out top alot of Puch polinis especially with some engine portwork and a larger intake...etc., but that's not the point of this setup, its a solid, quick, kitted motobecane, what else can you ask for.
I got lucky on the tuning, so all i can see from it are pros really, $60 odd dollars for ripping hill power, le sick!
La resistance 4 life!
  Review: Moby Mallossi Varioplus variator (AV7)Topic by: elliot of the resistance elliot of the resistance 12/12/07 12:26AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: mauvescorpion mauvescorpion 12/12/07 12:29AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 12/12/07 01:38AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 12/12/07 02:12AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 01/15/08 07:24PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/12/07 03:34AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: leefungchow leefungchow 12/12/07 04:43AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: The Gordon's Fisherman The Gordon's Fisherman 12/12/07 01:57PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Tommy Too Tall Tommy Too Tall 12/12/07 03:17PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Tommy Too Tall Tommy Too Tall 12/12/07 03:22PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot of the resistance elliot of the resistance 12/12/07 05:34PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 12/12/07 05:41PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 12/12/07 05:46PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: JCampbell JCampbell 12/12/07 05:46PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: pylo pylo 12/12/07 07:38PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 12/12/07 08:41PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Eric Sabatino Eric Sabatino 12/15/07 02:01AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Harry Crank Harry Crank 12/13/07 02:15AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Rafter Rafter 12/13/07 03:12AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Freebird Freebird 12/13/07 04:31AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 12/13/07 01:28PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Freebird Freebird 12/13/07 01:31PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 12/13/07 02:31PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Ben Ben 12/14/07 06:19PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Eric Sabatino Eric Sabatino 12/15/07 02:07AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliotonbella elliotonbella 12/15/07 02:38AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Freebird Freebird 12/15/07 05:41AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/15/07 05:49AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: WariSesi WariSesi 12/15/07 01:22PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot on bella elliot on bella 12/15/07 04:46PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: The Gordon's Fisherman The Gordon's Fisherman 12/15/07 05:07PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Ben Ben 12/16/07 01:24AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Eric Sabatino Eric Sabatino 12/16/07 02:54AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Ben Ben 12/16/07 05:15PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Tommy Too Tall Tommy Too Tall 12/16/07 05:48PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: The Gordon's Fisherman The Gordon's Fisherman 12/20/07 02:32PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot on bella elliot on bella 12/20/07 04:31PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 12/20/07 06:10PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/20/07 06:36PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 01/16/08 06:25PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 01/16/08 10:35PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 01/17/08 12:04AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 01/17/08 12:51AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 01/29/08 11:09AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: بهس&amp بهس&amp 01/29/08 11:59AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Tommy Too Tall Tommy Too Tall 01/29/08 12:06PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Tommy Too Tall Tommy Too Tall 01/29/08 12:17PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 01/29/08 02:03PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 01/29/08 03:06PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 01/30/08 07:15PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Shalerrr rrr Shalerrr rrr 01/30/08 07:19PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Jesse Stephenson Jesse Stephenson 01/30/08 07:25PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 01/30/08 07:40PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 01/30/08 09:12PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 01/30/08 09:37PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: pylo pylo 01/30/08 09:56PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 01/30/08 10:13PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 01/31/08 12:27AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 01/31/08 02:18AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 01/31/08 02:23AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 01/31/08 08:16AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 01/31/08 11:46AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 01/31/08 01:02PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 01/31/08 01:51PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Mr. Richard Dickrich Mr. Richard Dickrich 01/31/08 11:03PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: pylo pylo 02/01/08 06:52PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 02/01/08 07:37PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: pylo pylo 02/01/08 07:57PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 02/01/08 08:05PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 02/01/08 09:06PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bort Hoff Bort Hoff 02/01/08 09:19PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Mr. Richard Dickrich Mr. Richard Dickrich 02/04/08 03:38PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 02/04/08 04:35PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 02/04/08 05:16PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Shalerrr rrr Shalerrr rrr 02/04/08 06:31PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Mr. Richard Dickrich Mr. Richard Dickrich 02/04/08 09:26PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: peter peter 02/04/08 09:33PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 02/04/08 09:52PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 02/04/08 09:52PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 02/04/08 09:54PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 02/04/08 09:55PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Erin Erin 02/04/08 10:14PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 02/05/08 10:55AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Erin Erin 02/05/08 11:31AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 02/05/08 12:36PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: بهس&amp بهس&amp 02/05/08 01:42PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Mr. Richard Dickrich Mr. Richard Dickrich 02/06/08 12:35PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 02/06/08 01:33PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Frostback Ditch Frostback Ditch 02/06/08 02:06PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Ian T Ian T 02/06/08 06:05PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 02/06/08 01:52PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Crackstar X Crackstar X 02/06/08 02:05PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 02/06/08 02:55PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Mr. Richard Dickrich Mr. Richard Dickrich 02/06/08 04:06PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Mr. Richard Dickrich Mr. Richard Dickrich 02/06/08 04:23PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Crackstar X Crackstar X 02/06/08 04:27PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Steve Steve 02/06/08 04:33PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 02/06/08 04:41PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Mr. Richard Dickrich Mr. Richard Dickrich 02/06/08 06:15PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Ian T Ian T 02/06/08 06:55PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: بهس&amp بهس&amp 02/06/08 08:30PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: elliot elliot 02/06/08 10:38PM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: .Allen Schlung .Allen Schlung 02/07/08 02:28AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Mr. Richard Dickrich Mr. Richard Dickrich 02/07/08 03:49AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Bert Bert 02/07/08 08:37AM
  Re: Review: Moby Mallossi Varioplus variator (AV7)Re: Cristian Luna Cristian Luna 04/26/11 08:06PM
