Re: the clapper
Graham Motzing /
well in that case, you would hook up the clapper to a 115v ac timed relay. the clapper would turn it on, it would run for a few seconds, and shut off, you'd have to mod/mount a snoblower 115v ac starter motor (i've got one i'll send you if you really want to do this) and some sort of ring gear. The clapper would turn on the relay, it'd crank for a second or so, hopefully shut itself off or something.
