It's too cold here to spend more than 15 minutes or so in the garage so instead of working on my CV 175 ignition I took a few minutes to make a timing tool for my Motobecane 50V and for the CV.
I based it on the tool someone posted on the MA site:
I stopped at the hardware store today and picked up the parts I needed... except for the spark plug which I rescued from my trash bin.
The bolt is metric with a pitch of 1.0
I drilled out the spark plug and notched the nut so I can more easily use it to measure depth.
Next I tried it all together:
Checked what it will do in use:
Then I reduced the bolt head so it will go into the cylinder:
This is now ready to test out on the bikes. For anyone not familiar with the concept you insert the tool in place of the spark plug. Then you turn the engine to TDC. The ram should rise. Then you spin the adjusting nut down so it just touches the tool body. Now you can set the ram. If you want 2mm BTDC you just unscrew the nut two turns (look at the mark on the nut and back it off two turns)... that's 2mm.
Next you back the engine up slowly until the nut goes down and just kisses the tool body.
That will give you 2mm BTDC. You can dial in whatever setting you want. It should work as good as that tool in the first picture, but the parts should cost around $3 and it should only take about 15 minutes to make.
Respectfully submitted, Terry Horlick
