cdi for vespa
where can i get a cdi for my vespa si and will i need it?
I am going to have a 70cc malossi kit with simonini case induction with a 19mm delorto race carb and malossi performance varriator.
Re: cdi for vespa
you're going to need a lot to do this setup.
<www.50cc.nl>
<www.moparts.tk>
noth of which you can get the CDI setup, but you have to replace a lot, i think the case, and crank are involved in this. look through, and ask fred from moparts, he's a good vespa link
Re: cdi for vespa
epic failure on the links
www.moparts.tk
www.50cc.nl
Re: cdi for vespa
and that's suppse to say both
Re: cdi for vespa
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
kenitic cdi will fit right on, you'll need the fly wheel too
cdi for vespa
My si engine came with a cdi. So, you could look for si parts?
Re: cdi for vespa
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
brennan, did that si motor come from europe somewhere? vespa did have stock cdi, but didn't think any were imported! awesome. what year is your si?
Re: cdi for vespa
I dunno. I only had the motor. Ted has it now, but I think he is missing the case half. Sucks too, b/c the bolt pattern for the stator is different than standard vespas.
It must have been a euro model, b/c it had a stock 10mm wrist pin too.
Re: cdi for vespa
weird..i thought the euro version with CDI had a 12mm wrist pin....investigate!
Re: cdi for vespa
i forgot to mention im putting on the simonini race crank too so i should be able to fit a cdi on there hopefully from what ive gathered from you guys and from research on my own. Thanks guys.
Re: cdi for vespa
It was from a si monte carlo. I got it in Clovis, NM... there is an air-force base there so who knows where it really came from. I only managed to get the swingarm half of the bike.
Re: cdi for vespa
doesnt the vespa have the same flywheel as most of the italian bikes like morini and minarelli if i remember right my ciao did but that was a few years ago
Re: cdi for vespa
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
no, they are different
Re: cdi for vespa
yeah im just getting the simonini cdi kit comes with all the shit you need to make it fit and if the flywheel needs replaced ill just use a kinetic one i happen to know of one thats lying around so it will work cause i need the cdi to use the race crank and case induction kit and cdi's are just nice.
