Re: hi comp e50
woolfster2 /
Having worked on a lot of kaw triples I would not cut anything here. since you milled the head i suggest you look into the intake port when the piston is at TDC and if the piston skirt is below the top of the port shave it to where it cant be seen. do not mess with the exhaust side of the piston at all.
