Re: weights
maciek /
last i was running 10g with the yellow counter-spring (polini65, 13.13, estoril), could use lighter with stock spring but it made it too hard to start the bike, right now the motor is out to do case work and drop in a top crank, then I should be able to use lighter weights, but it really depends on you and your bike; heavier weights will push out more at lower rpms, lighter weights will take higher rpm, it sounds like you need to go heavier. try packing them with lead to 7+g and if that's not enough you have to figure somethign else out.
