Re: weights
adam /
I actually found ones that will work, but the real question is how much weight is everyone running and what is their setup?
Grande
- Kitted
- 13/13 Carb
- Perf air filter (lulz)
- Race crank
- Malossi Variator with stock weights
- Stock spring
Currently it takes off crazy fast as expected and the RPMs are too high once it starts to variate. I read similar reports all over regarding the stock weights. There have been surmises as to which weight (10g+?) would produce the best results, but no reports on which weight has actually worked the best on different setups.
So what's everyone running?
