19mm dollerto's. help me out
im thinking about getting a 19mm dollerto from 1977 buuuuutttt, ive got a couple questions.
what exactry is flanged vs. spigot? i know they are mounting types but i need more info for the decision.
this will go on a 65cc metra, does anyone have pics of their custom made intakes (seeing as how you need one custom made...)?
are there different jets for this thing or did i read it right when it said there is an adjustable jet?
will i need anything else with it?
Re: 19mm dollerto's. help me out
Flange clamps on, is more like a "female" version, and a Spigot is more like a male version, and you will use a rubber hose to connect the two "male ends". I like Clamp for the simplicity, but hard to get to fit correctly on a home made intake w/o leaking, so I'd say go rubber mount, which will also absorb some of the shock and shake of a moped. I've never made a Metra65 intake bigger than boring a stock intake, but I hear people use exhaust headers.
its the exhaust header from a tomos. peabe did this for his metrakit. it works if you work it..hehe. cut it down my friend. cut it down
cool. anybody got pics of their custom intake?
also, if I were to open up the intake port a bit, should i just open it horizontally or what should i do for best performance on the metra?
