would the polini reed cages fit a tomos a35 even though there ment for puchs? if so what would be a better size for a balls out a35 70cc kit techno extroil upgraded ignition case match? there are 15 and 19mm intakes available but i heard a 16 or 17mm carb is ideal for the tomos. should i go big? ill doo any other upgrades necessary to run with a bigger carb. i want to run a phgb carb. if they don't fit what other options do i have to replace the tomos reeds?
