jet size
i'm running a stock 12 mm bing carb on my stock puch kromag. i was taking the jet out to see what size it was, it's a 52, and i stripped the hell out of it and need a new one. i also took the restrictor out of the air filter, and was told to upjet to get better performance. treatshq has jets, but the smallest size is 62, and i am currently running 52. i don't want to buy anywhere else cause the prices are ridiculous. would 62 be wayyy to much gas for my ped or would it be ok?
thanks!
Re: jet size
E-mail Benji at Treats - I bet he can get you any size jet you need - it just may not be listed on the site.
Re: jet size
you should probably run a 27.
Re: jet size
uhh...27? do you mean 72?
Re: jet size
no 27 or 28 sounds about right.
Re: jet size
i thought the higher the number, the more fuel flow?
Re: jet size
It's been my experience that if you go much over #56 in a stock 50cc engine, you'll start to bog at low end, and 4 stroke at the top end. Plus or minus some gearing changes.
Re: jet size
i'm pretty sure small# means bigger jet with bings.
Re: jet size
I think it's the higher the # the larger the jet in for all mopeds.
