Re: Swingarm mod. bearings at the pivit point
Chris Paz /
Not only dose the rubber dampen the vibration it also adds slop to the rear end. If you remove the shocks you can push/pull the swingarm to the right and left. That removes almost all the feedback your rear wheel is giving you and I like to know what my back tire is doing. That's why I like riding on the rigid so much more than on a regular maxi.
MB5 swingarm is an option but there is a lot of modification involved and you loose your pedals. I am working on another way that should work with the stock swingarm but that is going on the magnum project and I have said too much already.
  Swingarm mod. bearings at the pivit pointTopic by: Adam Adam 11/14/07 02:03AM
  Re: Swingarm mod. bearings at the pivit pointRe: lee's anus is leefungchowOG lee's anus is leefungchowOG 11/14/07 02:05AM
  Re: Swingarm mod. bearings at the pivit pointRe: Zack Bandit Zack Bandit 11/14/07 04:49PM
  Re: Swingarm mod. bearings at the pivit pointRe: Adam Adam 11/14/07 06:04PM
  Re: Swingarm mod. bearings at the pivit pointRe: Adam Adam 11/14/07 06:03PM
  Re: Swingarm mod. bearings at the pivit pointRe: Graham Motzing Graham Motzing 11/14/07 04:36AM
  Re: Swingarm mod. bearings at the pivit pointRe: Adam Adam 11/14/07 06:05PM
  Re: Swingarm mod. bearings at the pivit pointRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 11/14/07 04:52PM
  Re: Swingarm mod. bearings at the pivit pointRe: SchijnHeilig SchijnHeilig 11/14/07 05:36PM
  Re: Swingarm mod. bearings at the pivit pointRe: elliot elliot 11/14/07 05:42PM
  Re: Swingarm mod. bearings at the pivit pointRe: scott scott 11/14/07 06:13PM
  Re: Swingarm mod. bearings at the pivit pointRe: Adam Adam 11/14/07 06:26PM
  Re: Swingarm mod. bearings at the pivit pointRe: Warisesi Warisesi 11/14/07 06:10PM
  Re: Swingarm mod. bearings at the pivit pointRe: Chris Paz Chris Paz 11/14/07 06:59PM
  Re: Swingarm mod. bearings at the pivit pointRe: SchijnHeilig SchijnHeilig 11/14/07 07:03PM
  Re: Swingarm mod. bearings at the pivit pointRe: Zack Bandit Zack Bandit 11/14/07 11:50PM
  Re: Swingarm mod. bearings at the pivit pointRe: Adam Adam 11/14/07 07:39PM
  Re: Swingarm mod. bearings at the pivit pointRe: Chris Paz Chris Paz 11/14/07 08:34PM
  Re: Swingarm mod. bearings at the pivit pointRe: Warisesi Warisesi 11/14/07 10:48PM
  Re: Swingarm mod. bearings at the pivit pointRe: Jesse Stephenson Jesse Stephenson 11/14/07 10:57PM
  Re: Swingarm mod. bearings at the pivit pointRe: cocoloco cocoloco 11/15/07 12:29AM
  Re: Swingarm mod. bearings at the pivit pointRe: Chris Paz Chris Paz 11/15/07 01:38AM
  Re: Swingarm mod. bearings at the pivit pointRe: Graham Motzing Graham Motzing 11/15/07 04:08AM
  Re: Swingarm mod. bearings at the pivit pointRe: SchijnHeilig SchijnHeilig 11/15/07 05:36AM
