i lust kitted my pa50II and i was running it and adjusting the carb and no matter what i do it wont reach any where near mid rpm never mind high rpm! full throttler and nothing but smoke and low rpm. any suggestions?
exhaust clogged?
are you reving it on the kick stand or are you talking about actually riding...
a. kickstand.. sounds like a clogged jet
b. sounds like bad clutch
did you rejet?
clean out the little holes in the holder pipe thing on the jet there are holes in the side for airbleed
The exaust and carb are clean the were cleand a cupple of weeks befor i got the kit. i think theres waaaay too much oil in the mix. i pulled the plug and it had a load of oil on it and it was clean when i put it in. the kit ran grate for about 45 minitus and then it started getting crappy.
Maybe you blew an oil seal? is the smoke REALLY thick and blueish??
PA50's don't have transmissions with oil in them. So if he blew a crank seal it would just stop running.
what are you jetted at?
When you find jets for these carbs you'll be rich! 60's and a 70 only ones ever made. That I know of. I do know they made a 13.5 carby in sa for these pups.
They don't make any other jets for these unless you get the carby kit off 50cc.
It was the exhaust i pulled it off and started it up and it ran great. is really loud so im looking for a performance exhaust, any suggestions i know promas arnt made any more im thinking about moding a 2pc biturbo.
Don't run it without a exhaust. Clean it with oven cleaner and it soak. You'll lock it up tighted then a drum.
Look for camino exhaust. Not pa50II no performance pipes.
lol
