Re: av7 vs. av10
Arran /
No, the top ends are different, the first thing to take note of is that one is crank case inducted, the other is piston port inducted. Get a top end kit for an AV88 engine, it is almost a bolt on to an AV7 crankcase.
If you want to go the AV10 route, just buy the whole thing in performance pieces, by the time you import a stock engine, even if you get it cheap, it will cost you more in the long run after you upgrade it. I would ask Bret Hoffman about the AV10s, I'm not that familiar with working on them.
