19m Dellorto Carb on Polini Garelli WHAT JET# ???
Hi!
I've got a Garelli with a 70cc Polini kit and a 19mm Dellorto carb and some type of aftermarket exhaust.
What main jet should I use???
Re: 19m Dellorto Carb on Polini Garelli WHAT JET#
start with the 85 in there now and add some sort of air box, not hi-flow, and see how you're doing.
There is currently a 76 installed and a Malossi Air filter.
Am I too small?
how does it run? Do you know how to recognize lean and rich carb settings by feel? or plug colors?
I don't really know too much about those.
The plug is a light milk chocolate color.
Hey Rock, I know this post is ancient but I was just wondering what your consensus was. I am running a similar set up.
Re: 19m Dellorto Carb on Polini Garelli WHAT JET# ???
lol
Rock Rockiki
Last Login: April 8, 2009 (edited)
mine likes a 92 main jet and a 38 idle. Also an AU 262 atomizer, 40 slide and w9 needle on second to the top clip setting.
What kind of exhaust are you running, Bergs?
Well at lest he did a search.
i have the weak ends pipe
Ed - Dead Possums /
