where did you guys source the clutch pulley on yr bikes with the doppler, et al, variators? Are you using the var's with the idle bearing?
treatshq had them a few months back, rcv-team.com has them and labecanerie.com might have them too. you use the variator w/o the idle bearing.
yeppers
