just ported 1 half of my case..i think
how do i know if i did enough work to feel the new found power, and also does the port work have to be exactly identical to the other side?
also, is there anyone who wants to finish porting/port my cylinder, i dont really have the tools to do a good job
its an m48 laura-anker motor
.................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................. these are for all the periods and punctioation missing in all my posts lol.
Re: just ported 1 half of my case..i think
Pics? I want to see Laura guts.
Read up on port matching in the tuning wiki, it should get you started. Make sure to examine the part closely so you know where everything is and what it does so you don't open up a hole where there should not be one. You can always remove more but if you remove too much you can't go back.
Yes you want them to match as close as you can get it, at least considerably better than stock, that is the point. also make sure you cut the gasket to match, unless you are using no gasket or gasket maker.
laura guts are a misuse of two stroke technology.
haha
its a laura-anchor motor you mean. you use it to keep your boat from floating around.
i'm doing some work with m-48's now that everybody in our fucking crew and their grandmother seems to have dragged a batavus out of some barn somewhere, expect to see some good shit posted.
idk
But long lines of text with no space make
the post unpleasant to read.
1
2
reeds 3
3
intake
intake 1
tiny reed
reed
Re: tiny reed
btw you dont bend reeds like that, your asking for trouble kids playing with there toys.
Re: tiny reed
is that a stock bat reed?
Re: tiny reed
Cleats Onionpockets /
Use the macro setting you dolt, everything comes out blurry otherwise. And also, you'll break or badly bend your reeds pulling on them like that.
Lastly, you might have incrased you intake size, that's fine. But what have you done about the exhaust port? The transfer ports? The transfer timing?
And didn't you crash that bike?
Re: tiny reed
i did use the macro setting u dolt its a crappy close up camera, dont worry thre reeds are fine they are really thick, the exhaust port has been opened up, the transfers are matched to the case, and has a little work done on them, the timing is the same as stock but im going to add 3 base gaskets to change that, yes i did, but i fixed it and its getting a complete overhaul
Re: tiny reed
haha...then buy a better camera you dolt! (I love that word...such a harmless insult lol)
They might be thick, but you still shouldn't weaken them by bending them that far, unless you plan to immediately replace them.
Re: tiny reed
i know lol and what is a dolt lmao and yes i am with carbon fiber
