I am installing a 70cc eurocylinder kit on my puch maxi, and I cannot see down the intake when the piston is all the way back. Is this bad?
do you mean eurocylindro? the reed valve?
do you also mean that you cant physically see the piston or that the piston is in the way?
You shouldn't be able to anyway. The gas gets sucked in through the intake hole when the piston is UP, not down. When it's down the exhaust port should be uncovered.
