tomos a3 to a35 engine?
so what all is needed, i have a complete tomos a3 bullet, Do i need a crank and trans or everything.
Re: tomos a3 to a35 engine?
Someone has got to have an answer for this!!
What are you trying to do exactly? A complete A35 motor will bolt onto the bullet frame. If your trying to convert your A3 motor with A35 parts thats more difficult. A few things changed between the A3 and the A35 which makes it impossible for most tomos A35 parts to fit the old motor. If your interested in fabrication and modification I do have an untested theory which should work quite nicely however I haven't tried it yet. If your looking for bolt on you could grab a complete A35 engine and wiring on ebay and slap it on your old model bike.
going from a A3 to A35 you'll need to install the voltage regulator, and put 12v bulbs in.
ah the hassel, Looks like the a3 motor has become my porting dummy
