Thanks For All The Help!!! Here is my Ped
Turned out to e multiple electrical gremlins and a bad seal on the head gasket!!!! Oh and jetting, fun..... !imageurl!
Sick
Sick man
Re: Sick
thanks
Re: Sick
its not often you see tricked out tfr's
i dig what you've done.
Re: Thanks For All The Help!!! Here is my Ped
nice bike josh. i have ATV handlebars too that i'm going to use on something...haven't decided yet on what though. i cut mine down a little bit too
You stole my kickstand! ;)
Nice ped :)
100cc simonini kit time!
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
rocking the ghetto lean!
Cleats Onionpockets /
I love that look, the twin led headlights are perfect for that bike. I agree with Graham, tfr's are too often neglected in the performance and dolling-up catagory. You've done a lovely job there.
Were all your modifications cosmetic? Or did you include a few performance tweaks as well?
Aside from the pipe that is...
proma curcuit
65cc polini kit
13.13 carb
oh and i variated it.
more to come
where can i find this?????
what the 100cc kit? heheheheheh MUUHHAAAHAHAHAHAAHAH!!!! (they have 80cc malossi kits, and up for vespa/tfrs)
<img src="http://www.jmpb.nl/shop/images/3276simoninikitciao.jpg">;
Simonini Aluminium 48mm '100cc' cylinder kit.
$217.00
Simonini Aluminium cylinder kit.
48mm diameter.
30mm exhaust port.
Comes with a matching high pressure cylinder head.
This cylinder kit is only meant for the Simonini engine
(you need the simonini crank case and the whole 9 with this
if you pay attention to the add, you might recognize the site..that a direct copy and paste
Good god, look at all those transfer ports
Then I assume we'll be seeing more of you soon?!
for sure ,i would have been there tonight but I got called into work, next week for sure, thanks again guys!!!
Just so you .. and stop saying 100cc.. and or 90cc.... Most or all kits are OVER rated in CC. Only a couple are not. Btw fyi.:)
Slap a RAG on that, now!
its in the works tuct tape sucks
Only thing I see wrong with that bike (it's all a matter of opinion of course) is the bar stock you've got hooked up in place of shocks. I never did like hardtails myself, especially when you don't have much padding in the seat. A set of black glossy outer-coil shocks would look amazing on that insted. Again, just my opinion.
with rigids, i suggest using spring seats, then it aint so bad. my ciao and moby are rigid, i saved the spring seat, and it doesn't hurt as bad as people with the welded up seatpans...that just sucks!
Nice grim! sure a difference from the previous pic you had up in your profile thumbsup
Wow, I think one might need the speed case side reed valve intake to support a bigger carb to support that huge a kit. ditto on the transfer ports, it's like the third one on the polini but all the way around!
Oh yeah, more pics please!
