Porting is easy steve, even a girl could do it.
Seriously tho if you use rifflers which are curvy end files, you can do your port job without mistakes. Takes way longer then a dremel but with a dremel one bad slip and it gets real expensive.
no point really in doing one without the other and if you have considerable down time in the winter you may as well go to town and do it all at once.
