case match vs port match
eventually im gonna crack my moby case to change out the bearings. i figure while im there, i want to do a case match. this is for a few reasons:
-I feel like it's easier and more straightforward than porting. case matching means you have two holes. make this hole the same as that hole. done. im decent with a dremel, some files, i think i can make it happen.
-i feel like i can get better performance with the case match.
is there any point on case matching w/o porting? porting still scares me, while the concept of case matching seems much more friendly. will it make a difference w/o the porting? is there anything else i should know before i do it? keep things smooth, round, no filings where they dont belong...
Re: case match vs port match
poorly titled post. should read "case match vs. porting"
Porting is easy steve, even a girl could do it.
Seriously tho if you use rifflers which are curvy end files, you can do your port job without mistakes. Takes way longer then a dremel but with a dremel one bad slip and it gets real expensive.
no point really in doing one without the other and if you have considerable down time in the winter you may as well go to town and do it all at once.
even a girl!?! haha i would use a range of tools im sure, but my issue is the insecurity and mystery of porting. with case matching, its "match this to this". with porting, there are a lot of variables. ie if i make it too wide i lose all my lowend or if I i make it too tall my timing goes to hell (these are just out-of-my ass examples, they may or may not be true but you get what im sayin). i guess i'll just ask this: if i port EXACTLY to the specs provided in the Wiki, what am i gonna get? I'll probably get some gains, but are there losses involved as well? i guess the way i see it is if there are some specs im DEFINITELY shooting for, with some idea of the results, then i can do it. if theres any mystery going on about what needs to be done and what the effects will be, i'm a little bit more reluctant. kinda makes me a wimp, but hey, i like my moby.
lee's anus is leefungchowOG /
if you don't take a risk and fuck shit up, you will never learn NIKE!!! just do it
haha a little more reckless than i try to be but yea, im starting to lean that way anyways. Kriedler shop manual "Nothing ventured, nothing gained"
porting isnt really that bad. you just have to be mindful of a couple things, especially concerning the exhaust port.
the exhaust port on motobecanes is that size for one reason -to limit power. raising the exhaust port will increase upper mid range to peak rpm power but will always take a chunk out of the low end, therefore i wouldnt advise rasing the exhasut port more than the 3mm or so that the artcile in the wiki suggests. however, you can also stand to widen the exhaust port a fair amount which will also increase the mid range to upper rpm power without sacrificing too much in the low end. as a general rule its not advised to make the exhaust port wider than 0.65-0.70 of the bore diameter (39mm). any wider and the rings will bulge out into the exhaust port too much and snag. when widening the exhaust port, its good to make the center of the top of the port 4-5 degrees higher than the ends. this will gently close the rings as the piston moves up in the bore and cut down on ring wear.
read 'two stroke performance turning' by A. Graham Bell (found here and that should help you out immensely.
sorry, here
shay is right, also put a bot of a camfer in the edges of the ports which will help ease the ring into position. also a clean passage is way better then a polished one so take any roughness off the port walls but do not polish it. obviously you have read some about the porting because you know what size and width will do to performance. the recipe on wiki is one that works for sure.
i read a bit of that book by Bell. definitely easier reading for me than that other one.. "two stroke tuners handbook" or something. i read up on the porting section a bit too, so i have all those formulas for actually calculating the ideal port size/durations. but i assume somebody already used formulas similar to that to get those measurements in the wiki anyways. im more than happy just to go by their specs, but my biggest concern is how much of a loss i'm going to experience in lowend from widening the 2mm on each side as specified. i can see myself doing about half the widening just cause im not wicked keen on doing a bunch of work, and in the long run actually just making a tradeoff. the 3mm seems a bit robust as well, i could see myself probably doing about 2. i think itd be better to start conservative and then go back for more if i want. and then yes, rounds chamfers smooth i think i can pull that all off. this.. all makes me think.. i need a timing cam puller. anyone know what shops sell em? thanks for the help,
-Steve
<www.Quarterkick.com>
They sell them, quick shipping too. Lot's of Moby goodies. Check your engine mounts and maybe get some new ones while you're ordering!
"Quarterkick":www.quarterkick.com
I suck.
just type it in.
yea i go there all the time, they kick ass. unfortunately their tool is out of stock though. once it comes back into stock ima order it.
I guess I got the last one! If you want to drive out to my house, you can borrow it. : )
hah, alright. nick from qk said theyd have em in soon. ill order from their next batch.
1977 has them for 20 bucks.
i prefer QK and QKs gonna have em soon. plus, are the ones on 77 for the clutch AND timing cam? it only says its for the flywheel and the clutch.
yeah it does both. i guess flywheel = timing cam
