what part exactlly do you have to shave off on the back wheel to make the 20 tooth rear sprocket fit. i think it is the rear hub? can some show me a picture please i would really apreaseate it.
take off wheel install sprocket put chain on sproket see where it hits thats it
It's much easier to change the front one.
you wont have to shave off anything. its a 20 which is small. i have a 22 right now and didnt have to change anything. usually you have to shave off parts of the body to make room for a bigger sprocket. for example if you were to put a 31 on the front you would have to shave off part of the body/casing and might have to loose your side cover
just realized all three of the "you" are lined up perfectly and that wasn't intentional...its a little weird.
With a 20 you will have to grind on the hub or space it out and use 420 chain to correct the alignment discrepancy. If you could find a 28 front sprocket you will get the same thing as changing to a 20 rear. 31 will make a real mess of things in the magneto chamber ith all the hacking you will have to do for clearance of the chain.
really? i would think it would only have to grind it down if it was bigger to make room for its size.
