what are your thoughts on putting a 31 tooth front sprocket on a 2007 tomos lx. what are the modifactions that are needed? ty
You will need to grind and hack the chain case into the Magneto side. Why not change the rear to a 20 and get 27 for the front, will give you almost the same thing without the butcher job.
although a great idea the only problem is you will never get anywhere if you live in a hilly area. You will certainly go fast but at the cost of butchering your acceleration. i run a 27 front 22 rear on a 1990 Tomos Golden Bullet and hit about 40 flat and 45 downhill the only real modification is that i use a expansion exhaust. Oh if it helps as an idea of terrain i live in richmond. although its mostly flat there are some hills (seven to be exact)
wow i feel like an idiot...i should have looked to see where you live first...what i said above is true but living in NJ hills arent really a problem as far as i know...although you willl lack acceleration, what double said above will work well for you
