HPI or Power Dynamo on za50
Will either of those aforementioned ignition systems work on a ZA50? I was cruising along on my 2speed when the flywheel came loose causing the woodruff key to shear off part off its little hole it sits in...So, I'm looking for an ignition setup that does not require a woodruff key.
Re: HPI or Power Dynamo on za50
thats a good question. i would post on puchforum.net to ask that though. very few peoeple have HPI experience in the US.
I know the HPI will work on a 2 speed.
really?
even though the 2 speed has opposite rotation?
Yes....does it really? If this is true that would be fantastic.
Frederick vdL /
I supply this HPI racing ignition.
264.60 dollars.
Those ignitions just need a trigger and the trigger doesn't care about the rotation of the crank it just triggers the CDI to discharge into the ignition coil. Essentially the trigger generates a positive or negative pulse.
-Naz
Anybody out there who has one, want to verify this on a ZA50?
yes it does work on a two speed. I own it. it can be set to any position on the crank there is no key slot. for left or right rotating motors, see instructions.
Can you post a pic of your set up, meaning your ignition with the cover off I have been having a hard time getting the timing right.
Lewis
where could i buy this ignition and where could i find more ignition on it? it will work on and small 2 stroke rite? tomos a35
