tomos sprint sprockets
What would be the best rear and front sprockets to get more bottom end power, And work well with a technigas exhaust or biturbo exhaust for top end?
Re: tomos sprint sprockets
John Joedicke /
27/22
I have the 28/22 set up and it's not all that much worse than a 27/22 setup.
you do notice it on hills if you don't have a head start though.
yeah thats what im worried about hills. Cause im planning on going to asheville (NC) in the mountains and i want a good set up
for low end you want a smaller front sprocket. stock is 26, go 25.
for high end you want a bigger front sprocket 27 tooth.
for low end you want bigger back sprocket. your stock is 22 teeth.
