Air filter I.D.?
What air filter is this?
Re: Air filter I.D.?
the filter was the last thing on my mind when i saw that motor. that's one hot peugeot
I know! I bought the pipe and carb off the thing! Im working on getting my 103 to 50 or so. But the carb which is a Dellorto PHBH 17.5 didn't come withan air filter so what one should I get? I'll be running a Polini 70cc kit and Ninja G3 pipe with it.
Just measure the carb when you get it, I think seattle mopeds and 1977 mopeds both have nice filters for the phbg which may be the same size. As for the filter in the pic, it looks like a generic k&n type.
go buy a breather for a muscle car from a performance shop. they'll have the size you can use, or either ccut open the rubber hole a little bigger to fit over the carb. just make sure you take the carb with you.
Thanks! Any other suggestions?
The guy decided to throw the filter in with the carb so my troubles are over. Thanks for all the help any ways guys!
Probably made by S&B look them up online, they are similar to the K&N, but cost about half as much. To replace it you'll need to know the outside diameter of your intake, and be sure there's enough lip to accommodate a small hose clamp to hold it on.
-Curly
Thanks!
