15 12 delorto bore job?
i want to make a 15/15 out of this extra carb I have, can I and is it worth it to do. What kind of gains should I expect to see if dome correctly. tips tools and opinions welcome here thank you for any advice you can spare time to give me.
Re: 15 12 delorto bore job?
You can indeed mill out a 12-14 on a lathe to 16mm or 5/8" but you must be dead on acurate. You need to remove and reinsert the emulsion tube (dab of epoxy) to do it right.
have you done it yourself and is it possable without a lathe and why sooo dead on cant i just drill it out and polish it up with a dremel or something
is it worth it for the gains compared to buying a bigger carb
You can buy a 15 or 16mm SHA carb for about $75 but the home bored carb will work similarly.
so are you sayn buy one or make one
I am sayin, 'If you got some extra cash to burn and less time to bore then buy the carb.' Another way to approach quandries as these in life is to flip a coin after having assigned one side of the coin to one of your possibilities.
good ideal heads for a new carb
tails i drill
TAILS im drilling
If you fuck it up you can always buy the larger one. Just be real slow and patient. Stop at times and study your progress and where you are taking that carb mod. Up jet
