Peugeot 103 Variator mod?
Ok, I know there's an easy one out there, I swear I saw it before I got my 103.
Searching yielded some nice info on a PA50 variator mod, but nothing solid on the Peugeot.
If someone could link me, that'd be super.
Thanks,
Zack
Re: Peugeot 103 Variator mod?
Guess I might not have actually seen this, or nobody who knows about it has seen this post.
Time for some exploratory wrenching then, hehe.
🦺πŸ₯‡b to the MOPO 🚨🚨🚨 eff /
Well, you can play with the weights, for one. I don't think there's a plate you can remove for better all-around performance or anything like that...
yeah there isn't much you can do without cutting on the variator, but then you might destroy it as well. I've swapped the weights out on mine and done some cutting but haven't done anything to aggressive with it.
for a moby
http://babelfish.altavista.com/babelfish/trurl_pagecontent?lp=fr_en&trurl=http%3a%2f%2fwww.ventilxp.com%2fforumv2%2fviewtopic.php%3ft%3d13407%26sid%3dd94deccd8da797e39868982289678fc0
-Naz
Well to keep on the variator theme I just swapped a malossi variotop onto my bike along with a bunch of other stuff. Hopefully I can manage to convince it to all play together well tomorrow or start and work.
-naz
Oh guess I should add a little bit of information concerning the photos. The top is 25mm is the low gear for the variotop and the bottom 34mm is the the low gear on the stock variator. It should be interesting especially since I have also added a polini launch pedal to my bike.
-naz
Let me know how that works out!
I'm as interested in the performance and the installation.
This is a good thread to keep going.
boring.
JK <3 U NA(d)Z!! :D
