Re: got ma' kit!
SchijnHeilig /
High pitch ringing sound indicates worn piston rings, which I can't imagine right now. If it's only when you release the throttle I wouldn't worry too much about it.
Keeping it under 25mph is not good. You do need to go to top revs now and then. Just remember not to ride the same RPM for more then 1 minute and you should be fine.
