will A3 cyl. head, fit on A35 cylinder?
i some how lost my stock a35 cylinder head and intake manifold so i found an a3 cylinder head that looks like if i make a gasket that'll fit it should work on my airsal a35 67cc cylinder but i'm curious how the compression will be affected but i run high octane gas with octane booster in every tank so if the compression is too high i'm sure it won't preignited the fuel, please give me some feed back and i need to find an intake that i can buy online that is slightly larger than the stock intake that i lost to replace mine so when i go to a larger carb i can bore it larger and use it with my hopefully soon to be purchased big ass carb, please help me out guys/ girls i need to get up and running asap thanx!
-Jamie Papp-
