Set up. 70cc with head, biturbo, 14intake, 15bing,aftermarket bing filter, 81jet, good point& spark. Wont start unless i use starter fluid, even then it takes 7-8-9- hard kicks. any sugestions?
hard to start usually equals low compression, or weak or bad spark
i have good spark & compression
check your timing
check your fuel delivery
Everytime I have had a bike that would only start with starter fluid, it has been a fuel delivery problem.
I'm not saying this is the case with yours, and I'm not saying this is the case _everytime_, I'm just saying.
Will check tomorrow. Would the 81 jet be to small for this setup?
probably not so lean that it wouldnt start
