Also if you take a compression test gage number and divide it by 14.7 you will get the compression ratio. And you can sand it down a lot before it gets too wild. Further, if you want to lower the compression you can add head gaskets or base gaskets. Removing base gasket equals more torque and adding base gaskets mean more RPM.
