Re: milling a head for compression (DIY)
b to the eff /
Plate glass and emery cloth.
You can substitute a slab of imitation marble since plate glass is so expensive. Get the really flat stuff (no cracks in the surface).
To measure thickness, get a pair of calipers. Measure how thick the head is when you start, then figure out your target thickness. Check often.
