HELP! where can i get a A35 intake manifold ^ I.D.
what company or site sells larger id intake manifolds for tomos a35 engines i want to run a larger carb than stock i lost my original intake manifold so i need a new one i know a lot of people have to fabricate larger tubing onto the stock housing to match the larger carbs but is there any way i can buy just the intake manifold part that attaches to the cylinder head and holds the reeds in place and from there i can make the rest unless anyone knows of a good aftermarket one i can buy, thanx
-Jamie Papp-
Re: HELP! where can i get a A35 intake manifold ^
resources, articles, recommended moped shops
look for a daelim
If you have a stock exhaust, a larger intake and carb won't give you much of a performance boost. If you have a performance exhaust already... then by all means go for it. I have a straight intake you could modify if you can weld aluminum. e-mail me if you need the intake. $5.
-Eric
eric i'm interested on buying your intake that will fit my square reed cage on my airsal a35 cylinder, and how i would need to modify it in order to fit my stock carb i need your email adress in order to contact you, mine is rx7jamie@hotmail.com
