I have a spare cylinder, which prettty much matches up with the slow cylinder model. The transfer port height was 5mm , where on my faster cylinder it was 8mm after mapping the ports. It was almost impossible to ride in traffic (22-23 mph top speed) unless you are suicidal. I ported the exhaust and the intake port according to the wiki, but didn't make the intake wider. No matching of the intake to the intake header nor any piston modification. The only difference between my "fast" and "slow" cylinder are the height of the transfer ports! I replaced the stock head gasket (0.6mm) with a gasket cut of a pepsi can (0.15mm) to raise compression. Timing, of course, had to be adjusted . Compression is 150 PSI. The ID of the intake is 13mm and I am running a Gurtner 212.xxx.
She runs now on the slower cylinder in the 30-35mph range according to the Hurret speedo. That's all I wanted...Now I am off porting my "fast" cylinder.
Thanks elliot,shaler, peter, eric and for whoever I forgot, for all the porting info.
Mike
