PEUGEOT CARB UPGRADE?
HI FOLKS. I HAVE A VERY LOW MILEAGE 1980’ 103. IT IS COMPLEATLY STOCK AND OF CORSE IT NEEDS A CARB, WHAT JR, HIGH STONER DESIGNED THE GUNTER CARB THEY PUT ON THESE THINGS? THE PLASTIC PIECE ON TOP HELD IN BUY ONE SCREW IS JUST THE FIRST OF THE FLAWS!!
ANY WAY I WOULD LIKE TO PUT A BETTER CARB ON IT FOR NOW THAT IF DOWN THE ROAD I WANT TO PUT A BIG BORE KIT ON ALL I WILL HAVE TO DO IS JET IT UP.
CAN ANYONE SUGGEST A CARB AND WHERE TO GET IT AND WHAT IT WILL TAKE TO PUT IT ON, LIKE CABLES AND SUCH?
I HAVE HEARD THAT DELLORTO MAKES SOME THAT FIT AND THEY COME WITH ALL THE NESSESARY STUFF TO PUT IT ON BUT I DONT KNOW WHERE TO GET IT OR WHICH MODEL WILL BE BEST FOR ME.
ANY HELP WILL BE GOOD.
J.
Re: PEUGEOT CARB UPGRADE?
I HAVE HEARD THAT USING CAPS LOCK MAKES YOU LOOK LIKE A JACKASS
🦺πŸ₯‡b to the MOPO 🚨🚨🚨 eff /
Get a dellorto. Buy it from a moped shop. I'm not sure what size will work well on a 103.
I just put a 14.12 on a peugeot 102 yesterday. I used a square cut from the plastic top to a planter's peanut tin as the plastic gasket where the carb connects to the intake because the stock one was too small, and it was too big to fit without anything.
btw I used a 57 jet, runs great.
THANKS FOR THE CARB INFO,,,EXCEPT FOR SHAY WHO SHOULD GET A LIFE AND A GIRLFRIEND, BUT WITH A NAME LIKE SHAY I'M THINKING HE MIGHT WANT A BOYFRIEND.
And I used the mesh filter
and make sure to use some gasket sealer on the intake and carb. Sorry for the multiple posts, I just keep remembering more info that may be important to you
Wow. 35 year olds from New Jersey, sound _just_ _like_ 15 year olds from New Jersey!!!
Why didn't you use one of the plastic spacers?
I DO NOT KNOW OF ANY GASKET SEALER THAT HOLDS UP WHEN USED IN FUEL SITUATIONS. WHAT TYPE DID YOU USE FOR THE CARB TO INTAKE?
why are you yelling?
If you buy one of the plastic spacers that are made for dellorto carbs, I don't think you need any sealant at all.
YOU KNOW I'VE HEARD THAT INSULTING SOMEONE WHO YOU ASKED FOR HELP MAKES YOU LOOK LIKE A JACKASS, ESPECIALLY WHEN ITS SHAY, AND YOU ASKING ABOUT A FRENCH BIKE, BE COOL
(Seriously though dude, turn off the caps lock)
yeah in all seriousness i think you can use a dellorto 14:12 on it. anything else requires a different intake to provide more clearance for the carb. (it gets in the way of the swing arm or when the motor variates...im not sure.) i'd also get the cable choke version of that and go ahead and replace both the throttle and choke cables. maitland did this and used a 68 jet and said it worked good.
What i'm planning now is to buy a 15.15 dellorto and a 12mm pollini intake along with a pollini reed / cage kit.
Someone told me to buy a 15mm intake but the guy i spoke to at Moped cafe didnt tell me it was available, Is it?
Truth is i haven't found anyone who could recommend a compleat set up. Carb, intake, reed setup and jet size.
I would love it if someone could
I'm putting this all on a stock low mileage 1980' peugeot 103 with the plan of using the stock muffler and possibly down the road installing a big bore kit, maybe 65cc but never changing the muffler . It only has 1200 miles on it and sat for a long time with a bad gurtner,,,,,,were they ever good? No i didnt think so.
My hopes are to make this ped do 45mph on flat ground and not die on hills. I dont want to go to crazy with it as i know how these peds would shake every part off if you went too fast. When i was 16 i had a 80' or 81' tsm that went 63mph, varifide by a new car with a digital dash. I didnt build it i bought it that way so i dont remember what had been done to it,,,it was 16yrs ago. I think it had a 65cc kit and a dellorto but not sure which one and the stock muffler. No idea what rear sprocket it had, must have been small though cause it took a while to get up to that speed
c'mon sissy's go for the 20mm dellorto PHBG or go home.
Mallossi 4 reed intake.
jet size 95.
i have a polini 70 on my 103.
talk to treatshq, he'll take care of you, he used to have a water cooled 103 or so he says, :P
Yeah kirk, i know. but u just want it to go to 7-11 or the post office and back from time to time. I have a harley roadking and trying to take it out to run erands in town is a watse of energy. I was going to buy a yamaha zuma but i had a couple of peugeots when i was a kid and just thought it would be cool to have one again for my in town erands
