top racing crank?
Troy Brown /
Whats the deal with the stuffed crank, compared to the other ?
Re: top racing crank?
Troy Brown /
tbrd OP
Anybody using a stuff crank on there e50? Waiting to buy a new one for my Maxi, and need some imput
lighter then the stock crank = better throttle response
ask smitty....
Frederick vdL /
The full crank, if that is what you meant with stuffed, will supply your engine with more, how should I say this...'pressure'...... Thus indeed like PyRo says, better throttle response, more power, possibly higher speeds...
i have a stuffed crank in my 65cc E50. i love it so far and have no complaints
I.R.E. Mike Pee /
Would this crank work on a korado e50 with a CDI?
I.R.E. Mike Pee /
Someone's got to know. Would this crank work in a korado?
Troy Brown /
tbrd OP
thanks for the info. I put one on order for my e50 rebuild.
yes. but yer korado crank is already pretty bad ass. you probably wont see a huge improvement.
I.R.E. Mike Pee /
I wasn't worried about better performance really, more about engine longevity.
