Re: Pic of my H20 cooled moped
Tony Soprano /
Well the engine is a Yamaha YZ series, polished as you can see. Boyesen pro series reeds, high compression head, Wiseco piston & sleeve, Kevlar Barnett clutch, Wiseco forged clutch basket, custom cooling port (cut and weld as the stock is in the wrong position, same for the h20 pump port) The engine has numerous internal modifications and is quite literally a race engine.
With the engine came the addition of a radiator that is mounted via brackets to the right side of the frame the radiator placement allows the front tire to act aerodynamically as an air dam forcing air through the radiator. Radiator is fed by stainless cooling tubes located below the frame, standard heater hose is utilized to make the final radiator and engine connections. The outside air dam is standard Yamaha issue.
The intake flange is custom as I need to angle the carb off to the side, a small section of high temp race silicon hose mounts up the carb to the flange. Bike retains handlebar controls for the clutch and the choke.
The adapter plate that mounts the engine to the final drive I made on a CNC Machine, I am working on a new set of adapters for the engine to swing arm mounts.
The exhaust is a Pro Circuit Ceramic race pipe, this has been modified and the revised mounting system remains constant with the geometrical articulation of the rear wheel.
Gas tank is designed after a fuel cell, petcock is mounted over the rear tire for access (since body work conceals most of the mechanics of the engine). It is all aluminum, fully welded and notched for extra capacity over the spark plug.
Rear luggage rack has been modified to accommodate the fuel tank.
The moped maintains the center stand which has been revised to use the lower engine mounts as the fulcrum on which to pivot, a child can easily lower the center stand.
The forward controls are custom fabricated from plate steel, custom shift linkage, which is fully adjustable as to rider preference and weight. The moped retains standard motorcycle like controls shift linkage on the left rear brake on the right.
The seat is being re-covered, and is a standard height adjustable bicycle type seat, standard for a moped.
I'll take more pics tomorrow and get them posted
  Pic of my H20 cooled mopedTopic by: Tony Soprano Tony Soprano 09/20/07 01:50AM
  Pic of my H20 cooled mopedRe: brystheguy brystheguy 09/20/07 01:58AM
  Re: Pic of my H20 cooled mopedRe: Hellarad Johnnny Johnnny Hellarad Johnnny Johnnny 09/20/07 02:28AM
  Re: Pic of my H20 cooled mopedRe: Tony Soprano Tony Soprano 09/20/07 02:33AM
  Re: Pic of my H20 cooled mopedRe: b to the eff b to the eff 09/20/07 04:01AM
  Re: Pic of my H20 cooled mopedRe: Cory Cory 09/20/07 01:53PM
  Water pump is by YamahaRe: Tony Soprano Tony Soprano 09/20/07 07:14PM
  Re: Water pump is by YamahaRe: Shalerrr rrr Shalerrr rrr 09/20/07 07:22PM
  VR6 in A1Re: Tony Soprano Tony Soprano 09/20/07 07:42PM
  Water pump is by YamahaRe: brystheguy brystheguy 09/20/07 09:39PM
  Re: Pic of my H20 cooled mopedRe: Chris Paz Chris Paz 09/20/07 03:07AM
  Re: Pic of my H20 cooled mopedRe: Chris Paz Chris Paz 09/20/07 03:09AM
  Re: Pic of my H20 cooled mopedRe: Tony Soprano Tony Soprano 09/20/07 04:36AM
  Re: Pic of my H20 cooled mopedRe: Crackstar X Crackstar X 09/20/07 08:43AM
  Re: Pic of my H20 cooled mopedRe: jake jake 09/20/07 08:45AM
  Re: Pic of my H20 cooled mopedRe: steve steve 09/20/07 10:25AM
  Re: Pic of my H20 cooled mopedRe: Crackstar X Crackstar X 09/20/07 10:40AM
  Re: Pic of my H20 cooled mopedRe: m6onz5a m6onz5a 09/20/07 10:52AM
  Legally its a mopedRe: Tony Soprano Tony Soprano 09/20/07 03:48PM
  Re: Legally its a mopedRe: Crackstar X Crackstar X 09/20/07 03:50PM
  Legally its a mopedRe: brystheguy brystheguy 09/20/07 04:00PM
  Re: Legally its a mopedRe: Crackstar X Crackstar X 09/20/07 04:33PM
  Legally its a mopedRe: brystheguy brystheguy 09/20/07 04:49PM
  Re: Pic of my H20 cooled mopedRe: cocoloco cocoloco 09/20/07 01:24PM
  Re: Pic of my H20 cooled mopedRe: Crackstar X Crackstar X 09/20/07 01:35PM
  Re: Pic of my H20 cooled mopedRe: Arran Arran 09/20/07 04:25PM
  Re: Pic of my H20 cooled mopedRe: dallas dallas 09/20/07 01:44PM
  Re: Pic of my H20 cooled mopedRe: Silverfox Sullivan Silverfox Sullivan 09/20/07 01:46PM
  Re: Legally its a mopedRe: jake jake 09/20/07 03:56PM
  Re: Legally its a mopedRe: the ultimate the ultimate 09/20/07 04:29PM
  Re: Legally its a mopedRe: mauvescorpion mauvescorpion 09/20/07 04:13PM
  Re: Legally its a mopedRe: Aaron Aaron 09/20/07 04:23PM
  more picturesRe: Tony Soprano Tony Soprano 09/20/07 04:47PM
  more picturesRe: brystheguy brystheguy 09/20/07 04:53PM
  Re: more picturesRe: Tony Soprano Tony Soprano 09/20/07 04:58PM
  Re: more picturesRe: Tony Soprano Tony Soprano 09/20/07 05:11PM
  Re: more picturesRe: Polomask Polomask 09/20/07 05:55PM
  Re: more picturesRe: terry dean terry dean 09/20/07 04:57PM
  Re: more picturesRe: jake jake 09/20/07 05:01PM
  My Honda H22 powered trikeRe: Tony Soprano Tony Soprano 09/20/07 05:18PM
  Re: My Honda H22 powered trikeRe: Tony Soprano Tony Soprano 09/20/07 05:20PM
  Re: My Honda H22 powered trikeRe: Tony Soprano Tony Soprano 09/20/07 05:21PM
  Re: My Honda H22 powered trikeRe: Tony Soprano Tony Soprano 09/20/07 05:22PM
  Re: My Honda H22 powered trikeRe: Polomask Polomask 09/20/07 05:56PM
  Re: My Honda H22 powered trikeRe: Rian Nickels Rian Nickels 09/20/07 05:33PM
  Re: My Honda H22 powered trikeRe: jaker jaker 09/20/07 05:36PM
  Re: My Honda H22 powered trikeRe: b to the eff b to the eff 09/20/07 05:44PM
  Re: My Honda H22 powered trikeRe: JCampbell JCampbell 09/20/07 05:51PM
  Re: My Honda H22 powered trikeRe: b to the eff b to the eff 09/20/07 06:03PM
  Re: My Honda H22 powered trikeRe: steve steve 09/20/07 06:04PM
  Re: Water pump is by YamahaRe: elliot elliot 09/20/07 07:27PM
  Re: Water pump is by YamahaRe: Troy's Quid Troy's Quid 09/20/07 07:27PM
  Re: VR6 in A1Re: Shalerrr rrr Shalerrr rrr 09/20/07 07:56PM
  I kinda like the 20V TurboRe: Tony Soprano Tony Soprano 09/20/07 08:26PM
  20v 4 cylinderRe: Tony Soprano Tony Soprano 09/20/07 08:31PM
  Re: 20v 4 cylinderRe: steve steve 09/20/07 08:37PM
  Re: 20v 4 cylinderRe: Shalerrr rrr Shalerrr rrr 09/20/07 08:41PM
  Re: 20v 4 cylinderRe: Tony Soprano Tony Soprano 09/20/07 09:17PM
  Re: 20v 4 cylinderRe: b to the eff b to the eff 09/21/07 12:21AM
  Re: 20v 4 cylinderRe: steve steve 09/20/07 09:20PM
  Re: Water pump is by YamahaRe: steve steve 09/20/07 10:17PM
  Tony Sop is lyingRe: mauvescorpion mauvescorpion 09/21/07 12:58PM
  Re: Pic of my H20 cooled mopedRe: elliot on bella elliot on bella 09/21/07 02:07PM
  Re: Tony Sop is lyingRe: Martin Martin 09/21/07 02:10PM
  Re: Tony Sop is lyingRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/21/07 02:16PM
  Re: Tony Sop is lyingRe: Polomask Polomask 09/21/07 02:36PM
  Re: Tony Sop is lyingRe: Erik Elhammer Erik Elhammer 09/21/07 02:19PM
  Re: Tony Sop is lyingRe: homoped homoped 09/21/07 02:43PM
  Re: Tony Sop is lyingRe: Rian Nickels Rian Nickels 09/21/07 02:47PM
  Give the guy a breakRe: CharlieH CharlieH 09/21/07 03:15PM
  Give the guy a breakRe: brystheguy brystheguy 09/21/07 03:33PM
  Re: Give the guy a breakRe: jaker jaker 09/21/07 03:30PM
  Re: Give the guy a breakRe: Cleats Onionpockets Cleats Onionpockets 09/21/07 03:44PM
  Re: Give the guy a breakRe: Tony Soprano Tony Soprano 09/21/07 06:13PM
  Re: Give the guy a breakRe: Martin Martin 09/21/07 05:33PM
  Re: Give the guy a breakRe: Graham Motzing Graham Motzing 09/21/07 05:47PM
  Re: Give the guy a breakRe: Cleats Onionpockets Cleats Onionpockets 09/21/07 06:27PM
  Re: Give the guy a breakRe: Zachary Evans Zachary Evans 09/22/07 08:27PM
