compression testing
Ive got some running mopeds but how does one go about testing their compression?
Re: compression testing
Thread in the tester, hold the throttle grip WOT and kick it over a few times.
into the spark plug hole right? WOT? is a tester costly?
Yes, it threads right into the spark plug hole. Mopeds have a 14mm spark plug hole. "Wot" is wide open throttle. I think sears or most auto parts places have ones around $25-30. You could probably find them cheaper if you search around. There are two types, a thread in and a push in type. The thread in type is best.
will it also gauge top dead center?
no
Ben Van Zoest /
You could buy or borrow one like this!
can someone please explain why you are suppose to hold the throttle wide open?
people say this all day long, but it makes absolutely no difference in the final reading
I would think to make sure your getting fuel in there to make a nice seal with the oil?
