Re: Viva LaResistance. French bikes need fast pip
elliot on bella /
you can buy an av10 bottom end for 43 euros from rcv-team.com
http://www.rcv-team.com/F_frame.html?http://www.rcv-team.com/
and since anyone going for the av10 is going for a kit just order that at the same time, and if your on a $$$ crunch use a good condition av7 crank and get new bearings too, brand new av10 with kit for the same price as a heavily used on on ebay.fr
u can use av7 points and an av7 variator (use all 3 balls or the crank will snap) as long as u mill the edge of the plate down on it (or sand on a block for along time)
hear is my idea of the cheapest way to enter the av10 game today assuming u got an av7 already:
buy the new cases 43 euro, buy performance reeds 12euro (cheapest), buy a 15mm curvy av10 intake 9 euro dellorto 15:15 29 euro sorce a good av7 crank with good bearings or use yours, buy seals at the bearing shop $10, use av7 points on the av10 cases, and the av7 variator, use the stock pipe, use the av7 cylinder with a piece of steel bolted over the intake.
93 euro = $130 + $10 seals $140 plus shipping $40 or less probably so for $180 your bike is now runs on the av10 base. and has a dellorto 15:15 take that away and run the gurtner for $140 shipped
you could ride this bike forever with this setup it won't go any faster than your av7 but it would be ready to upgrade wenever you get some cash on hand.
ps the leovinci pipes are nothing but trouble unless your creative in mounting them to av7 and 50v frames and for the price the ninja is much better. also the ball joint system on the leo's strip stock cylinders hella easy they are not well designed, and slower overall.
however the ninja on my 40 hits the ground all the time and has finally wore a crack thru the seam, also the baffle has exploded and the ball joint leaks, all of these things happening has to do largely with the overal neglect of my bike and the pipe, it was mounted loose and i did not know for over a month and that rattled apart the baffle and the ball joint, extra springs should fix the joint, the baffle i fixed with ahose clamp done, and it slung too low on the 40 with the stock mounting brackets to really be safe. My friend allens on his 50v however is honding up great and has no problemes at all yet,
peter you should swap with his at sac mine is literally almost in pieces
  Viva LaResistance. French bikes need fast pipesTopic by: Mike Scouty McScoutington Mike Scouty McScoutington 09/13/07 01:15PM
  Re: Viva LaResistance. French bikes need fast pipRe: Shalerrr rrr Shalerrr rrr 09/13/07 01:49PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mike Scouty McScoutington Mike Scouty McScoutington 09/13/07 01:56PM
  Re: Viva LaResistance. French bikes need fast pipRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 09/13/07 02:16PM
  Re: Viva LaResistance. French bikes need fast pipRe: peter peter 09/13/07 02:21PM
  Re: Viva LaResistance. French bikes need fast pipRe: Shalerrr rrr Shalerrr rrr 09/13/07 02:50PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mark Mark 09/13/07 02:59PM
  Re: Viva LaResistance. French bikes need fast pipRe: Peter Peter 09/13/07 03:27PM
  Re: Viva LaResistance. French bikes need fast pipRe: Doug Ler Doug Ler 09/13/07 03:33PM
  Re: Viva LaResistance. French bikes need fast pipRe: Cory Cory 09/13/07 03:41PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mark Mark 09/13/07 03:56PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mark Mark 09/13/07 03:47PM
  Re: Viva LaResistance. French bikes need fast pipRe: Erin L Erin L 09/13/07 03:50PM
  Re: Viva LaResistance. French bikes need fast pipRe: Shalerrr rrr Shalerrr rrr 09/13/07 04:13PM
  Re: Viva LaResistance. French bikes need fast pipRe: Weeder Weeder 09/21/07 01:43PM
  Re: Viva LaResistance. French bikes need fast pipRe: Nick Jobbitt Nick Jobbitt 09/13/07 04:16PM
  Re: Viva LaResistance. French bikes need fast pipRe: Arran Arran 09/13/07 04:20PM
  Re: Viva LaResistance. French bikes need fast pipRe: Nick Jobbitt Nick Jobbitt 09/13/07 04:23PM
  Re: Viva LaResistance. French bikes need fast pipRe: Arran Arran 09/13/07 04:46PM
  Re: Viva LaResistance. French bikes need fast pipRe: elliot on bella elliot on bella 09/13/07 04:46PM
  Re: Viva LaResistance. French bikes need fast pipRe: elliot on bella elliot on bella 09/13/07 04:51PM
  Re: Viva LaResistance. French bikes need fast pipRe: nate nate 09/13/07 09:45PM
  Re: Viva LaResistance. French bikes need fast pipRe: kirk kirk 09/14/07 02:29PM
  Re: Viva LaResistance. French bikes need fast pipRe: Brendan Connolly Brendan Connolly 09/14/07 06:18PM
  Re: Viva LaResistance. French bikes need fast pipRe: peter peter 09/14/07 11:23PM
  Re: Viva LaResistance. French bikes need fast pipRe: Crackstar X Crackstar X 09/15/07 10:09AM
  Re: Viva LaResistance. French bikes need fast pipRe: Mike Scouty McScoutington Mike Scouty McScoutington 09/16/07 10:45AM
  Re: Viva LaResistance. French bikes need fast pipRe: Chad Burke Chad Burke 09/16/07 12:01PM
  Re: Viva LaResistance. French bikes need fast pipRe: Arran Arran 09/17/07 01:03AM
  Re: Viva LaResistance. French bikes need fast pipRe: Mike Scouty McScoutington Mike Scouty McScoutington 09/16/07 12:12PM
  Re: Viva LaResistance. French bikes need fast pipRe: kirk kirk 09/16/07 03:08PM
  Re: Viva LaResistance. French bikes need fast pipRe: Arran Arran 09/17/07 01:04AM
  Re: Viva LaResistance. French bikes need fast pipRe: Chad Burke Chad Burke 09/16/07 03:28PM
  Re: Viva LaResistance. French bikes need fast pipRe: peter peter 09/16/07 05:09PM
  Re: Viva LaResistance. French bikes need fast pipRe: Eric Sabatino Eric Sabatino 09/16/07 05:59PM
  Re: Viva LaResistance. French bikes need fast pipRe: naz naz 09/16/07 06:18PM
  Re: Viva LaResistance. French bikes need fast pipRe: peter peter 09/16/07 07:39PM
  Re: Viva LaResistance. French bikes need fast pipRe: Arran Arran 09/17/07 01:07AM
  Re: Viva LaResistance. French bikes need fast pipRe: elliot elliot 09/16/07 08:37PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mike Scouty McScoutington Mike Scouty McScoutington 09/16/07 09:30PM
  Re: Viva LaResistance. French bikes need fast pipRe: kirk kirk 09/16/07 11:19PM
  Re: Viva LaResistance. French bikes need fast pipRe: Chad Burke Chad Burke 09/17/07 12:24AM
  Re: Viva LaResistance. French bikes need fast pipRe: naz naz 09/17/07 12:24AM
  Re: Viva LaResistance. French bikes need fast pipRe: elliot elliot 09/17/07 12:57AM
  Re: Viva LaResistance. French bikes need fast pipRe: Shalerrr rrr Shalerrr rrr 09/17/07 01:01AM
  Re: Viva LaResistance. French bikes need fast pipRe: Shalerrr rrr Shalerrr rrr 09/17/07 01:22AM
  Re: Viva LaResistance. French bikes need fast pipRe: kirk kirk 09/17/07 01:51AM
  Re: Viva LaResistance. French bikes need fast pipRe: Mike Scouty McScoutington Mike Scouty McScoutington 09/17/07 10:56AM
  Re: Viva LaResistance. French bikes need fast pipRe: leefungchow leefungchow 09/17/07 02:05PM
  Re: Viva LaResistance. French bikes need fast pipRe: Eric Sabatino Eric Sabatino 09/17/07 03:02PM
  Re: Viva LaResistance. French bikes need fast pipRe: Ben Van Zoest Ben Van Zoest 09/17/07 05:09PM
  Re: Viva LaResistance. French bikes need fast pipRe: elliot elliot 09/18/07 12:45AM
  Re: Viva LaResistance. French bikes need fast pipRe: Mike Scouty McScoutington Mike Scouty McScoutington 09/18/07 02:40AM
  Re: Viva LaResistance. French bikes need fast pipRe: Eric Sabatino Eric Sabatino 09/18/07 01:19AM
  Re: Viva LaResistance. French bikes need fast pipRe: Shalerrr rrr Shalerrr rrr 09/20/07 07:19PM
  Re: Viva LaResistance. French bikes need fast pipRe: elliot elliot 09/20/07 07:29PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mark Mark 09/20/07 08:47PM
  Re: Viva LaResistance. French bikes need fast pipRe: elliot elliot 09/20/07 10:57PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mark Mark 09/21/07 12:34PM
  Re: Viva LaResistance. French bikes need fast pipRe: Cory Cory 09/21/07 12:36PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mark Mark 09/21/07 12:48PM
  Re: Viva LaResistance. French bikes need fast pipRe: Cory Cory 09/21/07 01:11PM
  Re: Viva LaResistance. French bikes need fast pipRe: elliot on bella elliot on bella 09/21/07 01:58PM
  Re: Viva LaResistance. French bikes need fast pipRe: Mark Mark 09/21/07 05:34PM
